I have both a stacked dado set and a router table.
When a rabbet is needed on the end of a piece of stock (plywood) 12" wide x 48" long, should I be trying to use either TS sacrificial fence or my RT fence to cut the rabbet? The piece just seems too long for me to ensure that I keep the end tight to the fence(s).
In the past, I have used a piloted rabbet set in my plunge router and just run it freehand, but there has to be a faster way.
I have even thought about building yet another crosscut sled (TS) to be used exclusively to cut rabbets and dado's on the TS.
I would be curious to get a consensus as to the most accurate.\/safest method.
Thanks in advance for your ideas!
Wayne
Wayne
