You have to aim for slightly over 1/2 clearance. I aimed for 1/2 on some drawers for the basement - forgot what I had learned before - and they are kind of tight. For subsequent drawers, I got it right.
Door skin plywood is a little under 1/8 and not expensive. HD around here carries it.
If you have access to a planner, you can also plane down solid wood to the thickness you need.
