Looking for opinions on cementing these into the holes.
Would you think there is a need to have anything in the center of the post below grade, like gravel or cement?
The more popular process seems to be poring quick setting concrete dry around the post and either add a gallon of water or just let the moisture from the ground harden the cement.
My thinking is that the weekest point is going to be at grade level regardless of what is inside the post.
I'm not really concerned anout wind shear as the 6x6 panels will be somewhat protected from the house on 1 side and plenty of trees on the other.
