So the last thing I need to do to call this office remodel done is to make the
crown and base moldings in the room--about 45 linear feet each. I've got
all the tools and router bits to do it but I'm having trouble pulling the trigger.
Here's why.
The molding will be solid cherry and will be clear coated when finished. 2 of
the walls are nearly 10' long, and I didn't want to see a seam in the middle
of the wall. I bought 2 cherry boards that are 12' long and wide enough
to get me all the molding I need for those 2 walls. As you can imagine
they weren't cheap. I still need to run them through my planer, rip a straight
line, etc even before I can step up to my router table. Once I'm there, I
don't know if I'll be able to shape a clean profile on boards this long.
So should I just bite the bullet, stay the course and have at it, and make
long moldings to avoid having to make a scarf joint OR should I just cut the
boards in half to a more manageable size, keeping the boards grouped together
so that when I do cut the scarf joint, it's not as noticeable? I think I'm
getting some weird OCD as I get older so my eye will go straight to that
scarf joint every time I enter the room.
Thanks, Paul
Here's why.
Thanks, Paul
LOL
