I'm putting in granite countertops and need some advice on supporting an overhang. I have an island where the countertop overhangs the edge by 12 inches on three sides. The total countertop size is 66" x 36". The granite companies recommend support for anything more than a 6" overhang.
This particular application won't allow for any visible brackets, so instead I am going to lay down a sheet a plywood a little smaller than the countertop and rout-out and imbed hefty steel bars in the plywood. Specifically I'm using 3/8" x 2" x 2' steel bars every 16" or so. The bars will essentially be in a sunburst patern, radiating out from the center of the island.
This is, by the way, an accepted method of supporting granite countertops.
So to make a long question short, what do you guys think is the best sheet-good to imbed the steel bars in? I was thinking baltic birch, but I've heard that the quality has gone way down hill over the last few years (I've never used it). Does anyone know of a reference on the relative strength and stiffness of various sheet goods (MDF, particle board, OSB, plywood, etc?)
Thanks for the input.
PS- not surprisingly, the granite installer won't give me specfic advice for fear that they will be held liable if the top cracks.
