So i debated whether or not to post these, but I figured I took the time to take the pics so I might just as well...
I had never worked with laminate or contact cement before and it turned out to be kinda fun... especially the part of peeling the goobers of glue off my fingers...mental note... wear gloves dummy...
In case your wondering, I made the slots in the end for the fence attachment and the ability to put on a micro adjuster and table extensions... I don't have a joiner in the budget for a long time so I have to use the router table so Im hoping the extension wings will make it easier/safer/better.
And it was extremely nerver racking when it came time to route the cutout for the plate... But once that was done it was pretty easy to put some scraps of 1/2" mdf against the guide boards to make the through cut out...
I also learned to not get too excited and chamfer the edges before the corners are rounded.
As for rounding the corners, I cheated and put some support boards and used a round over bit because im horrible at rounding corners free hand with a belt sander.
Thanks for looking. Any comments or ideas would be greatly appreciated.
Now if I can just find the time to work on it some more
As for rounding the corners, I cheated and put some support boards and used a round over bit because im horrible at rounding corners free hand with a belt sander.Thanks for looking. Any comments or ideas would be greatly appreciated.
