Ripping small & narrow pieces on table saw
  • niki
    • 566
    • Poland
    • EB PK255
    Good day
    I had to rip a few small pieces for some router table aid/fixture and I would like to share with you the method.
    I'm using an Auxiliary fence clamped to the rip fence...now, when I'm saying Aux fence.... give me some good width say, 4"~6"....you don't like to "drive" in congested areas, do you...
    Before clamping the Aux fence, give it a pass through the blade just to make sure that its parallel and consistent in width.
    The sled is made of 5/16" (8mm) "Floor panel" but of course, you can use plywood or MDF.
    It's very easy to make it, just a runner glued/screwed under the board...you don't need a fence but you can add one and use the sled as "multi purpose"...as I do...
    As you will see, I'm holding both hands on the trowel and that, doesn't leave too many hands or fingers to be used as a "Backer board" for the workpiece...saves a lot of money...(no need SS)...
    Regards
    niki
  • big tim
    • 546
    • Scarborough, Toronto,Canada
    • SawStop PCS
    As usual, Niki, well thought out and well illustrated!
    Tim
    • final_t
      • 1626
      Good idea/tip with putting both hands on/in the trowel handle - this forces your body out of the line of fire of the blade, so would avoid getting hit by anything flying out of the guard. Plus it forces all your body parts away to the side of the blade!
