Many manufacturers realize that what they print on the label may induce purchase regardless of its contents. One product that gets mentioned that falls into this category is Resisthane.
It's base solvent is "Dipropylene Glycol Methyl Ether. That chemical is a variation of Ethylene Glycol, which is the same chemical found in anti-freeze, which is water soluable. For other common products, this chemical is also present in these products.
Just to clarify the types of film finishes and their base (solvent), is pretty simple, there aren't that many.
Lacquer thinner (acetone based) - lacquer
Mineral Spirits (or Naptha, turpentine) - a variation of oil based coatings
Denatured alcohol - Shellac
Water - all water based (waterborne) coatings
This is a simplified listing, and the individual ingredients may vary as to binders, resins, carriers, etc. Basically the solvent acts as a carrier and an evaporative part of the formula. To know what the actual base of a finish is, the label will list what to use for "clean-up" or thinning.
So, the question of why Resisthane's label says "Pre-Catalyzed Lacquer" when it's not? It's likely that they are directing the product to the lacquer users, or those that think they are getting a "lacquer" finish, but are overjoyed at the thought it is less toxic, and cleans up with water.
The "Ethylene Glycol" content, or its derivatives is definitely a solvent of sorts. It will dissolve tarmac (asphalt), as you know if you've had a leaky radiator containing anti-freeze.
I've also seen products claiming to be a waterbased varnish. A description of finishes with the realities can be found here.
The only difference there is one carbon and three hydrogens.
