How many passes does it take to finish each cut when raising panels? I mean, after doing 10 rectangular panels I think I should ask. Does a router bit cut to its set depth on the first cut? I used featherboards on the table and on the fence to hold the work piece securely in place but, if I run the piece through again, it would cut more. It took about 3 passes to completely "clear" each piece. Is this normal?
I'm concerned now because my next panels are s-shaped for the top sides of a roll top desk. I will have to do these sort of freehand, using only the bearing as a guide. So, safety is my big concern, and I don't want to have un-foreseen difficulty doing these.
I'm using a shop-built table, a Bosch 1617EVS mounted to a Rockler Plate, and these bits https://holbren.com/product.php?prod...7&cat=0&page=1. I had no trouble with rails and stiles but am totally confused over the panel cutter. I cleaned this bit after every 3 panels knowing that the build up could cause problems. I'm running the router at (Bosch says), 13,500 rpm. The feed rate is just enough to bypass burning the wood..Oh yeah, it's red oak.
What's my problem? Or, should I say, do I have a problem?
Sorry for the long post,, I just don't know how to say what I'm thinking.
