Need some help please.
I want to make 2 slide out shelves for the very bottom of a cabinet. The shelf will be 3/4" plywood and it will basically be like sliding the cabinet bottom put to make it easier to get to the stuff in the back.
What slides do I use for this? I'd like them to mount between the plywood and the cabinet floor so that there is no more than about 1.25" of the height lost on the operation. I am not sure the 1/2" thick full extension slides can or should be used in this way.
Any other ideas? The KV1129 mounts on the bottom and I guess I could put one on each side.
