I'm about ready to start the finish process on a new field box for my helos. The box is all wood, mostly 1/8th ply. I want a really slick painted finish on it that will stand up to the high nitro fuel I use.
Here is what I'm planning to do. If there is an easier way or if this is a bad idea, I'm all ears so suggest away!!
1. Sand it down with 100 grit paper (all ready done)
2. Sand it down with 220 grit paper
3. Sand it down with 320 grit paper
4. Apply a couple coats of thinned poly to seal the wood
5. Scuff with steel wool
6. Shoot a couple coats of color (going to be blue & orange)
7. Apply my graphics/decals
8. Apply a top coat to fuel proof (poly?????)
What do you think? Will this provide a smooth, glossy and durable finish?
