trying to locate magazine article
  • Jbridge337
    • Nov 2004
    • 123
    • GA.
    I am trying to recall where I saw a magazine article so I can do the project. The article was in a woodworking magazine within the past few years and the topic was organizing (shelves) in a garage. The particular shelf I am interested in had a vertical suport (against the wall) a horizontal support (holding the shelf) and the structural integrity was a triangular shaped plywood rib (like an I beam) that was dadoed into both supports. I know I could figure out something on my own, but there are some specifics I would like to see in addition to some other projects in the same magazine. Sorry, this isn't much help. I had picked up the magazine one time while in the library and didn't photocopy the article or the cover.
    Thanks in advance for any help, I haven't had any luck with google or some of the magazine's search functions.
  • WayneJ
    • 785
    Jim,
    Try Shop Notes, Vol.16 Issue 93, pg 22 might just be the one you are looking for.
    Wayne
    Wayne J
    • Jbridge337
      • Nov 2004
      • 123
      • GA.
      magazine article
      thanks wayne, but that isn't it
      ________
      ________|
      | | @ / this plywood rib was dadoed into the other pieces similar to the engineered wood
      | |@ / trusses
      I am just trying to see some of the specifics about how they mounted to the wall etc.
      Last edited by Jbridge337; 02-22-2008, 07:11 AM. Reason: asci graphic formating not staying
      • williwatt
        • Aug 2007
        • 150
        • Springfield, TN
        • Sears 21829
        How about this article from Family Handyman? It sounds similar to what you described. http://www.rd.com/familyhandyman/content/17590/
        • Jbridge337
          • Nov 2004
          • 123
          • GA.
          Thanks williwatt, but not it either. hmmm
          • Jbridge337
            • Nov 2004
            • 123
            • GA.
            I finally found it. It was in Family Handyman - http://www.rd.com/familyhandyman/content/53401/
            plywood isn't dadoed into supports, but looks like a nice project. A little costly, but looks great.
