Making round doors or panels that are to be laminated with a Formica type product or veneer, is fairly easy. "Bending ply" can't be used for doors as there is no way to keep it in a curve. I use a variety of plywoods in 5/8" to 3/4" thicknesses.
You first need to have a form for the curve, such as a cabinet front or a made up form. Using a "tailors tape measure" or anything that will take the curve, like 1/8" masonite, measure for the inside length of the curve. Measure for the desired height, less the thickness of two pieces of the laminate or veneer to be used.
Orient the plywood so the face grain runs horizontally, and cut out the door. You will be cutting saw kerfs in parallel vertically. They will be of a depth just short of the face veneer of the plywood, or at least leave 1/16" or more. The grain running horizontally will help prevent cracking of the face. The spacing between kerfs will be determined by how tight the arc of the curve will be. This should be tested first. For very tight curves, the kerf will be deep and very close together. For very gradual curves, the kerfs may not be so deep, and may be further apart.
You should wind up with some flat on the two vertical ends to end the lamination. Once kerfing starts, the panel will become flimsy and you have to handle it carefully. Tack nail with small finish nails to the form (kerfs being on the outside/front), along the top and bottom edges nailing through the flats between the kerfs. Leave some nail head protruding so you can get it out easily.
Carefully fill the kerfs with a Bondo type mixture. You can't mix up too much at once as it kicks off pretty quick. With a putty knife, force the bondo into the kerfs as deep as you can get without breaking through. When the total area has been filled, and cured, remove from the form, and block sand the face smooth.
I make a block sander from using 3x21 sanding belts. I cut stock from 5/8" or 3/4" ply, MDF, or melamine, 3" wide and just long enough to force the belt over the block to stretch it tightly. I wind up with a two sided hand sander that is 3" wide and somewhere about 9" long, depending on whether you use 5/8" or 3/4".
You can then laminate with your choice of material. As for drilling hinge cup holes, make a mark on the inside of the curve where they go. Using a DP, carefully drill the hole after the door has been wedged at the correct angle, to the minimum depth needed. It's wise to laminate the outside of the door after the hinge holes have been drilled because you may break through if you've drilled too deep.
This method is for an outside curve. For inside curves, the backside of the door gets kerfed and filled as above.
This technique can be seen in this thread.
