I posted a new tutorial...
    If you are like me, you are seldom to get to the main bt3 page, as my browser auto completes to the forum page, so I thought I'd post a heads up that I did a little tutorial on treating veneer edges for book-match glue ups.
    You can check it out here....
    http://www.bt3central.com/showthread.php?t=36281
    thanks,
    It never hurts to learn new tricks. Thanks for the tut.
      Good tutorial. Great way of jointing. I've done it that way and on some veneers, I use a shop made block sander made using a 3x21 sanding belt. I cut a 3" piece of 5/8" or 3/4" anything just long enough to force into the belt to stretch it tight. It gives me a sanding block about 9 plus inches long that's easy to hold and is useful for other tasks that require flattening. I've experienced some veneers don't edge plane absolutely flawlessly.
      • downtheroad
        • Mar 2007
        • 79
        • So. California
        Thanks for posting your method.
        I do something similar when jointing for bookmatched soundboards and backs of guitars and other string instruments. These boards are thicker than veneer (3/16" - 1/4" rough). I use a shooting board. Here is a link I Googled that shows a method very close to mine.
        http://books.google.com/books?id=7fx...pEoYoI#PPA9,M1
        Tony
