Hello,
Nearly done with my first 'real' furniture project, a blanket chest for the teenage daughter. She's eager to have it and wants it in her room ASAP, but I've been stalling because to me, quite frankly, it looks like ****.
I don't have any aspirations of being the next David Marks, or even Norm anytime in the near future. But I do think the project should look reasonably decent. Part of me just wants to take a can of gasoline and a match to this one.
What I have: blanket chest built from plans in WOOD magazine. Used sugar pine from the local hardwoods dealer, and after a lot of trials and tribulations I got most all the joinery looking decent (ended up re-cutting a number of pieces). I put sanding sealer on per the directions, and then followed w/ a pecan colored stain. The color isn't an issue; the panels in the sides and ends of the chest, and the lid (all flat surfaces easy to apply stain to) look great. What looks terrible is all the mitered trim around the panels, and at the top and bottom of the chest. Basically anywhere that *wasn't* flat and smooth.
The stain I used was Minwax Polyshades Golden Pecan - two coats, sanding w/ 0000 steel wool in between. I used foam brushes of various sizes, which seemed to work fine when applying the sanding sealer. In hind sight, I have to wonder if a regular bristle brush would have worked better - it certainly couldn't have worked much worse.
I have basically a lot of dark blobs here and there around the corners and edges of the trim, and also a number of light spots where its almost like the stain didn't penetrate *at all*. I've tried sanding down the thick spots with no success thus far - barely seem to touch the PolyShades once its thickened like that, plus much of its in the contours of the molding. This really has me frustrated, as I made *sure* I had a nice even coat over everything, only to come back in the morning and find that apparently some stain had worked its way under the trim, and leaked back out to pool up, or that areas I'd covered apparently didn't take the stain - only along the edges, so I hesitate to think it was something with the sanding sealer coat.
The big question is... now what?!?
