What Do You Install First?
    Originally posted by lakkdainen
    I'm one of the few that replied bottoms first. There is a reason though... the set I'm going to do is for my basement bar, and the floor down there is nowhere near level. I'll have to get creative with leveling the bases, then once those are done I can measure from those and/or use a jig to hold the uppers in place while I screw em in.
    For a "normal" reasonably level floor, I'd probably do the uppers first though.
    FWIW, find the highest point, and level off from there. If you have a long level 6' to 7', or if you just have a 2', use a long straight edge with the level on top. Once you determine where the differential exists, if you can get away with the height, figure out what shimming you need to do. If you have a base/toe kick that can be trimmed you could do that also.
    When permitting, I make loose toe kicks. With those, it's easy to level.
      The only complete kitchen I have done was to replace an existing kitchen. Like somebody else commented, I replaced a cabinet (or multiple if they were connected) at a time. I started with the tops because they were both more visible and easier to make (to me). I had the old base cabinet in place to help hold the cabinet up while I screwed it to the wall. Later I made the base cabinets (one or a few at a time), removed the old base, and installed the new base cabinets and countertop (I used ceramic tile on two layers of plywood).
      An empty wall cabinet without a door is not too heavy for me to just put in place with one hand while I screw with the other but my alignment might not be so hot and if I have to fasten it to another cabinet I will mess it up. A ledger is not great support. I have seen jacks that roll on the floor to help with installation but I do not have one.
      I built and installed a few cabinets in more of a kitchenette than a kitchen in the basement of our current house. I think I did the base first in that instance but at least part of the reason was so I could do the floor (I did not put the laminated hardwood I used under the cabinets).
      Lots of ways to get it done but it's good to think about it a bit before you start.
        We remodeled our kitchen about 6 years ago. One of my boys helped me with the cabinets. We put the wall cabinets up first. It was easy enough with one of us holding the cabinets, and the other screwing them in. As several others mentioned, I was concerned with the reach if the base cabinets were installed first.
        • shoottx
          • May 2008
          • 1240
          • Plano, Texas
          You Have to hang the top ones first!
          If you don't, what are you going to bang your head on?
