Easiest Way To Do This?
    This is a side view of the soffett for the bench project. The arc will be formed by 1/2" ply cut with kerfs. The sides will be rabbetted to receive the arc and the flat end pieces. I will rough cut the arc piece long so it can be flush trimmed once I know how long to make it. Question is, what is quickest way to get the ends of the arc flush to the top of the side pieces (in red)?
  • Duff
    • 164
    • San Antonio, TX
    • Enco 12" RT
    I'm probably reading this wrong, but I'll offer just in case. . .
    If you know the top corners are perfect 90', how about running it through the saw with one of those top corners against a HIGH fence attachement? That would (if you're blade is set to 90' also, make the red lines parallel w/the top (currently on the side). . .
    Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
      Ya know that is a good idea. I want the arc piece to sit in a rabbett but there's no reason the end pieces have to.
      Thanks!
