Cut List or CutList Plus?
  • MBG
    • Apr 2003
    • 945
    • Chicago, Illinois.
    I have heard a lot about CutList Plus, but, as a hobbyist I still find it hard to spend $90 for this software. It has a lot of neat tools for people in the business but I don't think I would use many of these.
    I recently found this software (free): http://www.delphiforfun.org/programs/cutlist.htm
    This Cut List program is not very elaborate but seems to work fine.
    I'm planning to build a futon that has 60 components. I wanted to compare the two software packages but when I hit the 25th piece the free trial of Plus stopped working so I couldn't get much of a comparison.
    I'm a new user to both programs but have a couple of questions about CutList Plus.
    1) Why is rough sawn lumber only listed as BF not dimensions?
    2) The project requires 1/2" thick slats but I can't enter my raw material as 1/2" thick dimensional lumber.
    From my experiment CutList Plus has a better user interface but the parts optimization seems almost identical on the free Cut List software.
  • siliconbauhaus
    • Dec 2006
    • 925
    • hagerstown, md
    Rough lumber is sold in BF so you buy it wider and longer than you need and then machine it.
    Maybe you could input 3/4 for the slats and your rough size?
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
      I have and use Cutlistplus. I bought the second highest in price license when I purchased it. I use it mainly to make cutting diagrams for sheet goods. I have used it for boards. One of my projects required re-sawing and then planning to 1/2" thickness. The only way I found I could do this was to input my stock sizes twice, so if I needed two 5" x 24" x 1/2" boards and I had a 5/4 x 6" x 36" board I'd tell the program that I had two boards in stock. On a different project I was using pine. I first ran the program with "unlimited" as a stock supply of 4/4 x 6", 8", 12" x 8', 10', 12' to get an estimate of how many feet (linear) that I would need of each width, added 10 or 20% because of having to work around flaws purchased the lumber and then updated the program with actual stock sizes. Only then did I lay out my cuts on each board. Even then I had to make some changes in part placement to avoid flaws. and maximize offcut size while minimizing waste. I still ended up with a bunch of kindling.
      Cutlistplus is a great program but nothing takes the place of actually making each part fit on a board.
      • footprintsinconc
        • 1759
        • Roseville (Sacramento), CA
        you could continue to use the free trial, but only build 24 pieces at a time (one model from pieces 1 to 24, then 25 to 48 ... )
        omar
        • MBG
          • Apr 2003
          • 945
          Thanks for the responses. I have about 10-5/4+ x 12" x 12' planks of rough sawn red oak. The freebie software (Cut List - not Cutlist Plus) was good enough to get me started. The program has options to cross-cut first, rip first, or combination. The first two are calculated in a flash. The optimized combination cut option took about 2-hours to run. Even if I don't follow the layout exactly it shows clearly which components to group together to save material.
