Exterior wood use
  • ironhat
    • 2553
    Exterior wood use
    I'm scoping out a possible job for a friend who wants to put a tonneau cover on his truc but he wants the snaps to be screwed into a wood rail that runs across the top of the bed. He wants to use oak but I reminded him of how ugly it can get when it weathers. He also wants to make the bows out of wood - don't ask. So, my questions are;
    1. What readily available species would be best for these top rails? I suggested hickory for strength of the screw hold.
    2. I suggested the Cabot's Australian Timber Oil that I used on my swing since I had to buy a gallon of it and have plenty. Do you see anything wrong with that?
    3. How 'bout the bows - don't know if hicory will bend very well but I guess he could go with maple since they won't see the weather.
    TIA, folks!
    Blessings,
    Chiz
  • jlm
    • Oct 2005
    • 137
    • Austin, TX
    Have you thought about ipe for the frame? It's a very weather-resistant wood, and hard as nails. Prettier than oak, too. It's an "exotic" wood, but it's seeing a lot of use in decks these days, so you should be able to find it relatively easily.
    • ironhat
      • 2553
      The Ipe is a consideration - I don't know how it looks under an exterior oil finish - but availability might be an issue. Thanks!
      Blessings,
      Chiz
      • scmhogg
        • 1839
        • Simi Valley, CA, USA.
        Chiz,
        How about Teak or Mahogany with a gloss marine varnish finish. Think yacht or a Chris Craft look.
        Try bent laminations for the bows.
        Steve
          My vote goes with Steve for Teak or Mahogany, but I would oil it. You could also use White Oak.
          • Jeffrey Schronce
            • 3822
            • York, PA, USA.
            • 22124
            White oak. QS if you want to get fancy. Sounds like a bizarre project. I dont think you will have any luck bending IPE or teak, though Mahogany will bend similar to white oak if steamed.
            • Knottscott
              • 3815
              • Rochester, NY.
              • 2008 Shop Fox W1677
              Cypress would be nice too...
