I've just installed my first set of drawers on a project and had a question about adjusting the slides for smooth operation. I'm using full extension ball-bearing slides and I mounted them using spacers to keep the height consistent on both the carcass and the drawer boxes. However, when I slid the drawers in, some of them are a little tight. More specifically, when opening or closing the drawers, it takes a little more force to move the drawers when the pieces of the slides come together. It's hard to describe, but if you think about full extension slides consisting of 3 interlocking bars (the piece attached to the drawer box is one, and it slides into the "center" bar which slides in the bar attached to the carcass), the drawers travel smoothly as a bar is extending from one of the other bars, but at the point in travel where one bar becomes fully enclosed in another (i.e., the travel of the drawer is being transferred from one bar to another) it gets stiff. My guess is that the width of the carcass is just a bit too much, putting stress on the slides, and the solution is to shim out the slides. Is this a correct assumption? Or am I missing something else?
Thanks,
Bryan
Thanks,
Bryan
