I just tried making some drawers for my shop, and somehow I cut the bottoms about 1/4" too short!
I used the method outlined by Bill Hylton in his router book, using a drawer lock bit to cut the sides, front & back, groove them and chamfer the bottom. I thought I allowed enough extra bottom to seat in the groove, but no such luck
Any advice for the math-challenged on how to determine the drawer bottom size? What I did was clamp together a front, side, and back, then measured the width. Then I found the depth of the groove, and added double that amount to the first measurement. I did a test cut (too short), adjusted the length, cut all my bottoms and then discovered they were still too short. Blargh.
At least they aren't in real furniture, so I can glue some ply over the crack and be done with it.
Would doing pocket-hole drawers with the bottom screwed to the bottom of the box be easier to do?
This is driving me crazy! I'm beginning to wonder if I need a different hobby--or only make bookshelves....
Thanks for letting me vent!!!!!!
g.
.Any advice for the math-challenged on how to determine the drawer bottom size? What I did was clamp together a front, side, and back, then measured the width. Then I found the depth of the groove, and added double that amount to the first measurement. I did a test cut (too short), adjusted the length, cut all my bottoms and then discovered they were still too short. Blargh.
g.
butt joint`s
for workshop drawers not so smart even i wouldnt be that bad, what about box joints?
