chalking with polyurethane
  • tellittojake
    • 50
    • toledo, ohio
    My father in law said that when he uses polyurethane, he sometimes gets what he referred to as chalking. I am not sure what he meant and could not offer a solution. Does anyone know what he is referring too? What is the reason for it? I told him I would post the question to try to get an answer. Any ideas out there? thanks.
    Chalking is usually refering to a powdery surface that rubs off on old paint. Never seen it on polys, though.
    • eddy merckx
      • 359
      • Western WA
      • Shop Fox Cabinet
      Wonder if he's thinning it with too much water. Even though it's water based, you're not supposed to thin with much more than 5% water before you risk messing up the chemical balance.
      Also wonder if he's straining the solid chunks out before applying.
      Eddy
      • tellittojake
        • 50
        • toledo, ohio
        poly
        I will ask if he is using water based, didnt think of that. I too have never heard of chalking in reference to poly. Thanks
        • Jeffrey Schronce
          • 3822
          • York, PA, USA.
          • 22124
          I just about guarantee that he is using old oil based poly. Bet $10 it has been sitting on the shelf for quite a while and has made it through a few weather cycles. I have immense knowledge in this department! You can only guess how I know this! LOL!
          Let me know if I am right.
          • tellittojake
            • 50
            • toledo, ohio
            old poly
            He does not do the amount of woodworking projects that I do and I wouldnt be surprised at all if it is old. I will have to ask him. thanks
