Folks,
I am planning to use a water based gel stain on a piece that I'm building. The wood that I'm using is maple. My question is how long do you normally let the sanding sealer set before sanding it? What would yield best results?
The reason why I am applying a sanding sealer before applying the stain is to reduce the blotching normally experience when finishing maple.
Greatly appreciate any info.
Thanks!
Thanks!
