With respect to the router's power plug:
Is it a bad idea to put a power socket inside the cavity where the router is going to be, then wire it to a switch on the side of the cabinet? I'm thinking the dust might accumulate inside the socket (unless I can find a single outlet one instead of the usual 2), but I've seen others do this so maybe my concerns are not valid?
The cavity where the router will be in is going to be enclosed (has a door).
Thanks.
Thanks.
That's a really nice and simple solution to the dust. Thanks.
