Drum Sander Project (in progress)
  • Rslaugh
    • 609
    • Punta Gorda, FL, USA.
    • None right now
    I don't think heat will be a problem with the drum design but i do think rigidity will be an issue if it is only supported on the ends. I would add some discs every 3-4" along the shaft. Keep posting progress!! Thanks
    Rick
    IG: @rslaugh_photography
    A sailor travels to many lands, Any place he pleases
    And he always remembers to wash his hands, So's he don't gets no diseases
    ~PeeWee Herman~
    • ragswl4
      • 1559
      • Winchester, Ca
      • C-Man 22114
      Originally posted by ExYankee
      I'm glad you are doing this, I have been considering doing something along these lines. I was thinking that if you drill a pattern of access holes into the drum and shot in Great stuff the expanding foam would provide added rigidity. The "over the top" type sander doesnt seem to build up heat since there is little torque on the drum.
      putting it the outfeed table is a good idea, if you made some sort of tension release on the belt it would also serve as a stock roller.
      Keep us informed of progress please.
      Would the "Great Stuff" have any problem with heat? It sounds like if may be a good way to add rigidity to the drum. Is that the same stuff that is used for insulation around doors and windows? Available at Lowe's or the BORG? Thanks for the interest.
      I am not going to put any effort into the out feed table idea (it is a good one) until I see that the sander works as expected. Right now its pretty darn heavy. With the motor added I am guessing its about 50 lbs.
      RAGS
      Raggy and Me in San Felipe
      sigpic
      • ExYankee
        • Mar 2005
        • 126
        • Pleasant View, Tn.
        • BT3100-frankensaw
        What is your source for the velcro and sandpaper rolls?
        Thanks
        John Dyer
        ExYankee Workshop...
        I think history would have been very much different if Leonardi DiVinci had a belt sander.
        • Scottydont
          • 2359
          • Edmonds, WA, USA.
          • Delta Industrial Hybrid
          These kind of projects are fun. I have not attempted one yet. Here is a like to a guy who designed on and offers parts for sale based on his design. Keep in mind his prices are Canadian.
          http://www.nicks.ca/Toolkits.html
          Here is another for kits and replacement sandpaper etc. I prefer the design and simplicity of this one. They have some other pretty cool stuff.
          http://www.stockroomsupply.com/
          Here is a link to a how to video from the stockroom website (very well done.)
          http://www.theonlinewoodshow.com/sho...er=20102&cat=1
          Edit: Sorry, I just noticed that rags already posted the link for Stockroom.
          Scott
          Edmonds WA
          No coffee, no worky!
          • bmyers
            • Jun 2003
            • 1371
            • Fishkill, NY
            • bt 3100
            Originally posted by ragswl4
            Here is a link to what I am attempting to duplicate. This should clarify what I am doing and also define the type of sander I will most likely end with. There is a video link on that sight but not a great one. Also the V Drum Sander uses a poly carbonate drum so it might be that this design overcomes the heat issue with the drum.
            http://www.stockroomsupply.com/V_Drum_Sander.php
            I like the idea of the turned hardwood drum. It would seem that would be more stable and add some weight which may in fact be needed. As I don't have a lathe that is not an option for me right now. (maybe a reason to get a lathe, though).
            With the bed up and out of the way, it sure looks like a lathe to me. Just needs a tool rest.
            I dunno if you have a BS but if you cut out MDF circles that are close to round and mount them on a shaft you can true them up IN the sander. Instead of putting sandpaper on the drum, put it on a flat MDF board and run that across your sanding bed. That would also ensure that your bed and drum are coplaner.
            You may be past that point already. It looks like you are making good progress. Looking forward to the results...
            • jarhead
              • 695
              • Boynton Beach, FL.
              Originally posted by bmyers
              ... I dunno if you have a BS but if you cut out MDF circles
              Bill,
              Reminds me of your drum sander project from ShopNotes. How is it holding up?
              • ragswl4
                • 1559
                • Winchester, Ca
                • C-Man 22114
                Thanks
                I purchased the sandpaper from stockroomsupply.com (maker of the V drum sander) and the Velcro mat from Woodmastertools.com. Both arrived today. I think the Velcro was a little pricey but I could not find a lot of sources so I just went with the company that was recommended by another sander builder that I found on the web. One thing I didn't think about and got lucky was that the Velcro and the sandpaper were not both hook or both loop. Didn't check that before I ordered and later saw sandpaper that was either hook or loop. Again, buyer beware.
                As soon as I get the Velcro and the sandpaper and the sander and do a test I'll post the results along with where/what/how much all the piece parts were. In the middle of rebuilding a RAS for my stepson that's building a house.
                RAGS
                sigpic
                • bmyers
                  • Jun 2003
                  • 1371
                  • Fishkill, NY
                  • bt 3100
                  #23
                  Originally posted by jarhead
                  Bill,
                  It's holding up just fine, I really like that one.. I almost built one of these so I'm curious to see how it turns out. Looks like he's almost there..
                  • ragswl4
                    • 1559
                    • Winchester, Ca
                    • C-Man 22114
                    #24
                    Well the acid test is over. The sander works pretty darn good. I have a little wobble in the last two inches on the right side but it sands pretty good. I started with 150 grit, made a couple of passes and then switched to 220 grit and made a couple more passes. Board came out smooth and took only about 2 minutes including the time it took to change the paper.
                    What I really like is that about 90% of the dust ends up in the box under the table top. Just a little dust on the top and not much into the air. After I add a dust collection port I think I won't have much dust escaping at all.
                    The velcro was very easy to put on the drum. Cutting the angle correctly was easy as well. Just measure the circumference of the drum (7 7/8" in this case) and using a straight edge, go from a corner on the angle where that measurement intersects the other edge. Worked perfect.
                    So I am very pleased with the results. I'll see how the drum holds up with time. Any problems and I'll redo the drum by making discs from MDF and gluing together and to the shaft. Next post I will summarize the costs and sources of the parts. Just finished laying 3.5 cubic yards of concrete and I am wore out.
                    RAGS
                    sigpic
                    • bmyers
                      • Jun 2003
                      • 1371
                      • Fishkill, NY
                      • bt 3100
                      #25
                      Hey that's great! Congratulations. I hope it serves for years to come. Post some pictures when you arms rest up from the cement.
                      • ragswl4
                        • 1559
                        • Winchester, Ca
                        • C-Man 22114
                        #26
                        So here is the parts list/cost/source I used to build this sander.
                        1. 3/4 HP motor from HF-$62.00 ($13 was tax and shipping)
                        2. Two pillow block bearings and two pulleys (5/8" and 1/2")- from SurplusCenter.com $40. ($12 of that was shipping)
                        3. 2 1/2" PVC pipe from Lowes- $4.00
                        4. Epoxy Glue from Lowes - $4.00
                        5. 1/2" steel shaft from Lowes-$6.00
                        6. Scrap MDF
                        7. Belt from Harbor Freight-$20. (could get by cheaper with a V belt)
                        8. 2'x4' Melamine Particle board from BORG-$8.50
                        9. Velcro Mat from woodmastertools.com-$40 ($14 of that was shipping and I have enough velcro to cover 4 more drums)
                        10. Three rolls of velcro sandpaper (Klingspor 150, 220, 320 grit) $42. ($13 of that was shipping and was 45 ft of sandpaper)
                        11. Scrap particle board to build the box.
                        12. Scrap Goncalo Alves to trim box.
                        13. Hardware (various nuts and bolts) from Lowes-$4.00 .
                        14. Electrical box, cover and switch from Lowes-$3.50
                        Looks like a total of $234 for the parts. The V drum sander kit from Stockroomsupply.com costs $199+$13 shipping. It includes the drum with shaft, bearings, pulleys, belt, velcro mat and some sandpaper. All in all it may not be a bad deal after all. You would still have to buy a motor, material to build the enclosure and the top. Also would have to buy a switch.
                        Shipping for the parts I purchased was over $50. I did look locally for some of the parts but the prices were higher that having them shipped so I went that route.
                        Stockroomsupply.com recommends a 1/4 hp motor for their 18" drum sander. That might be enough but I think a little more horses are needed. I will post some pictures of the finished sander as soon as I can. Thanks for your interest.
                        RAGS
                        sigpic
                          Great project, Rags!
                          Yeah, it looks like the kit would be a fair deal, given all the running around and such.
                          • ragswl4
                            • 1559
                            • Winchester, Ca
                            • C-Man 22114
                            #28
                            I would think so especially if one could find a good used motor. Try as I might I could not find one. In the end I am glad that I did this as I enjoyed the challenge and thankfully the result. I was not really paying attention to the total cost as I ordered the individual parts. I was more focused on getting the parts so I could finish the project (building frenzy). I feel like the sandpaper and velcro mat were the overpriced items.
                            RAGS
                            sigpic
                            • blame
                              • 196
                              • Northern MO
                              • delta ts-220 or something like that
                              #29
                              hey rags did you get action shots
                              blame
                              • iuseit
                                #30
                                velcro mat and paper from stockroom supply
                                Rags,
                                I just stumbled on your project details after searching for hook and loop paper. My sander is a bit different. More like this one:
                                http://www.rockslide.org/drum%20sander.html
                                It is almost complete. Only have some finishing work and to attach the hook and loop paper, etc. I modified the plans to take up to 5 1/2" thick to 20" wide. Even looking at Stockroom supply it is hard to tell where to order the mat from? I see the rolls of sandpaper with hook and loop but I don't see where to order the mat to glue to the shaft? Any hints? Or should I just call them and ask?
                                IuseIt
