Hey guys. Needed my new saw a couple inches higher to match my workbench that I normally use for infeed support. Also needed it up a couple of inches to clear the fence on my jointer which I put to the left side of the saw.
So I built a shelf -- 2x4 frame with plywood top and maple trim. What a job -- lifted the saw up off the stand with concrete blocks, 2x4's and bottle jacks, just enough to get the shelf in place. Turned out to be a lot of work. The bolts now go through the saw, through the shelf frame and into the stand.
Also moved the rails over about 12 inches -- had to drill new holes for the bolts front and back. Gives me about 43" of ripping capacity now so I'm happy.
http://ssmith1627.myphotoalbum.com/v..._0805Smith0095
http://ssmith1627.myphotoalbum.com/v..._0805Smith0096
Now I have to find some plans I'm happy with for a router table / cabinet I can mount in that right side to replace the small table there now. And I want to build another cabinet behind whose top will be the outfeed table.
Does everyone else spend this much time setting up shop ?? I know I spend 3 times as much time working on shop stuff as I do actually building things ! haha
Steve
Steve
