Paste wax on plastic laminate?
  • ryan.s
    • 785
    • So Cal
    I'm almost finished with my outfeed/assembly table which is topped with plastic laminate. Would it be okay to apply a couple coats of paste wax on the laminate? Any ill effects?
    I've asked several questions here while building the table. Thanks to the members here I was able to get all the answers I needed. For those that are curious I ended up finding black plastic laminate at HD. The couple times I went looking for black or white laminate I guess they were out of stock and only had only marble or wood grain designs. I went back thinking I would special order some but they just got a shipment in and had tons of white and black sheets. I ended up laminating only the top but sealed the underside with 2 coats of poly.
    Thanks.
    It may help things slide easier, sometimes too easy. Depending on what you use, you don't want it to get on anything that would interfere with an intended finish.
    • linear
      • 612
      • DeSoto, KS, USA.
      Works great for me, I wax my laminate router table top.
      It's also really easy to remove, just dampen a rag with mineral spirits and wipe it away.
      --Rob
      sigpic
      • ryan.s
        • 785
        • So Cal
        Thanks for the responses guys. I'll give it a try.
