I am using 3/4 inch MDF to build the carcasses of garage/workshop cabinets. Mostly, they are relatively simple boxes, but a couple have shelves made of MDF across the middle, in dados cut into the side panels. I believe this adds rigidity and some strength to the cabinets. I dry assemble them and they usually go together without a problem; the dados are tight, but the shelf can be inserted with just hand pressure.
The problem comes when I apply glue (Titebond II) to the dados and try to insert the shelf into the dado. They simply will not go, even when using a mallet to beat the other end shelf. I know that MDF has some tendency to swell when wet but I have had swelling to the point that I could not get the shelf to seat completely to the bottom of the dado.
I have gotten around the couple of problems so far by keeping my handy sander nearby, but I worry that this will result in a loose fit and I am not sure this is a good long term solution.
Is there any kind of rule of thumb that I could use to take this into account?
Regards, Steve
Regards, Steve
