Large Diameter Dowels
  • kgworkman
    • 35
    • Colfax, WA, USA.
    I'm going to be duplicating a game for some family members, but am having trouble finding the proper sized dowels.
    I need 1.75" diameter (44mm really) dowels. This is slightly larger than the standard closet rod which I had hoped to use originally.
    I wanted to keep it as "authentic" as possible, but may have to settle if I can't find anything large enough.
    Any help and suggestions would be greatly appreciated.
  • MikeMcCoy
    • Nov 2004
    • 790
    • Moncks Corner, SC, USA.
    • Delta Contractor Saw
    You might try a custom mill work company (hand rails and that sort of thing). Other than that, if you knew someone close by with a lathe, that would fix you up with any size you wanted.
    • linear
      • 612
      • DeSoto, KS, USA.
      Rolling pins?
      http://www.amazon.com/18-Rolling-Pin.../dp/B00024WN9K
      --Rob
      sigpic
        Here you are:
        http://www.americanwoodcrafterssuppl...cts/dowels.htm
        Birch, 36" long, about 3/4 down the page
        • TheRic
          • Jun 2004
          • 1912
          • West Central Ohio
          Find someone to turn some for you.
          Not sure how long these need to be. Take a walk thru Lowes / HD / etc looking everywhere for parts that might work (cut off the parts that don't work): railing, spindles, flagpoles, handle replacement (for broom, shovel, axe, etc.), curtain rods, etc.
          More than once I have gone thru a store looking for something without knowing what I'm looking for and finding something that would work. It's intended purpose for something totally different.
          Ric
          • gwyneth
            • 1134
            • Bayfield Co., WI
            Depending on how many you need and how unusual the wood is, you may want to make one of the dowel-making fixtures in Bill Hylton's "Router Magic"...one is very simple, one is a little more complex.
            • havighurst
              • Jun 2004
              • 181
              • Metamora, MI, USA.
              Sounds like a great reason to buy a lathe!
              • Stormbringer
                • 1387
                • Floral Park, NY
                • Bosch 4000
                Here you are:
                I would go with Ken's masterful find. Seems the quickest and, depending on how valuable your time is, the cheapest.
                Good luck,
                Greg
                • radhak
                  • 3061
                  • Miramar, FL
                  • Right Tilt 3HP Unisaw
                  Enter a Bed-Bath-and-Beyond store, and walk upto their draperies hardward section. You'd see a variety of curtain rods, many made of solid wood, and most would be pretty expensive (say, $40 for a 6 ft piece) because of the extra thickness.
                  But in that same section would be (could be) a box of one-off pieces which are sometimes as much as 80% discounted. LOML bought a bunch of such for a steal couple of months back - $8 for the 6 ft ones, and $12 for the 8 ft ones. . If you are lucky you would find plenty of them.
                  Like I said, I cannot guarantee it, but I have seen those more often than not.
                  Of course, if you need the exact thickness (44mm), I wouldnt know how you could trim any thicker dowels down....
                  - Aristotle
                  • kgworkman
                    • 35
                    • Colfax, WA, USA.
                    This is definitely the most attractive suggestion so far. Not sure I could make if fly though since this is not a LOML endorsed project.
                    I am forever in search of "a project in need of a tool".
                    I'll be checking out HD and a Bed bath and Beyond this weekend. Maybe I'll get lucky and save some $$$.
                    Thanks for all of the great suggestions!
                    • kgworkman
                      • 35
                      • Colfax, WA, USA.
                      To Lathe or not to Lathe
                      Maybe I could justify the lathe on the grounds of how much faster it would be to apply a finish...
