What is the best way to stain pine, plywood beadboard? I'm building a basement bar for my son and the panels are about 38" high by either 24" or 43" wide. Thus, lots of surface area.
I plan on sanding the surface of the panels, staining them and then applying wipe on poly with a rag.
As for the possible blotching problem, I plan on using Zinsser's SealCoat, a one-pound, dewaxed shellac, as a sanding sealer and then stain over that. Will that work?
Oil based stain or water based? While I like gel stain, I think it is a bad idea in this application.
Ideas? Comments? Thanks.
