Deck design question
  • thaar
    • 5
    I am thinking about redoing our deck with a different design as it is not in very good shape. However, I am not sure how to pull off this design.
    Currently, my joists run all in one direction spaced apart each 12". Will I have to put additional bracing perpendicular, in between each joist, to achieve this pattern, or is there another option?
    i.e. is this what I would have to do (install cross bracing)?
    ____<- current joist
    l l l l <- cross bracing, but spaced out more
    ____<- current joist, but imagine it higher up, connecting to the cross bracing.
  • movnup
    • Aug 2006
    • 190
    • Seattle
    The blocking can be put in at 16" on center with the pattern you have. If you go with a diagonal pattern then it would have to be 12" or 8" O.C. dependant on the angle used. As a lesson learned the hard way measure each blocking section and cut them to length one at a time as there can be a slight variation through the joist over the entire length and they could end up to be too short / too long.
    A great web site is www.decks.com as they have framing diagrams, stairs, footings, etc. and also lots of completed deck pictures of just about any style you can think of.
      As movnup said, the blocking should be installed at 16" on center to get that pattern. I do not know how big your deck is, but what I've also seen done once on a larger deck is to put a post in the center of the deck and run a doubled joists down the center to sit on the post. Then run doubled joists perpendicular to form a +. Then the joists are hung as normal in each of the sections but you change the direction to get the deck pattern you want.
      • Duff
        • 164
        • San Antonio, TX
        • Enco 12" RT
        How big is the deck area?
        Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
