I am building an "Ultimate Miter Saw Cabinet" for my new Bosch SCMS and have some finish questions. First, the carcass is made from 3/4" Cabinet Birch with one side finished. (I found this cabinet grade ply on sale here in town. Cheaper than the good birch ply at HD.) The finished side looks like oil-based polyurethane as some small strips at the ends had yellowed where the sheet had stuck out from under the stack for a while.
My questions are:
1. I have just purchased the HVLP sprayer from Rockler and want to know can water-based polyacrylics be sprayed through and generally how much water do I have to use to thin down for spraying.
2. If I use a water-based polyacrylic to spray the whole project will the finished side still turn yellow or darken under the polyacrylic?
3. If the finished side will yellow I assume it is better to complete the project with oil-based poly? Is the 50/50 ratio of polyurethane and mineral spirits/naptha a good spray ratio?
As always I appreciate all your comments in guiding me in the right direction.
My questions are:
