Drawer sliders
  • steve-norrell
    • 1001
    • The Great Land - Alaska
    Drawer sliders
    I am trying to locate some drawer sliders that attach to the bottom of the drawer AND extend out 100%.
    I have found both underside sliders and 100% extension sliders, but the extension sliders all seem to be the side-attachment variety.
    If they exist, I need 18" under-drawer sliders that can handle about 75lbs. each and which extend out 100%.
    All help would be appreciated.
    Thanks, Steve
    Here is one...
    http://www.rockler.com/product.cfm?p...e&cookietest=1
    and here is a better one...
    100 lbs load rating on both.
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      Also, when I buy any hardware that looks "tricky" to install (I'm a tad slow), I ask for an Installation Sheet - always been able to get one - takes all the pain away. They show necessary clearance measurements etc.
      Downunder ... 1" = 25.4mm
      • steve-norrell
        • 1001
        Here is one...
        Wow! That was fast.
        Only problem is that these sliders seem require attachment to the cabinet sides. True, the drawer part is on the bottom of the drawer.
        I want to install a peg-board goodie holder that will slide in and out of a cabinet-like space. The holder will not be against any side, but free-standing in the center.
        Did that truly muddy the waters? Regards, Steve.
        • dramey
          • Oct 2005
          • 42
          • Soldotna, AK, USA.
          Steve,
          I know how to do what you need done. Send me an e-mail and I will give you my phone number and call me and I will explain how to do it. e-mail me at david at davidrameyphotography dot com
          • steve-norrell
            • 1001
            Final Solution? (For now anyway).
            I wasn't as clear as I could have been in my previous posts. Although I said the sliding piece would be in the center, I should have added that it would also work with it up against a side provided that I figured out a way to get 100% extension.
            Well maybe this will work. The sliders are 100% sliders (but shown fully extended in these photos) that normally attach to the sides of drawers. In this case I attached them to the bottom and top of the pegboard frame and to the side of the cabinet opening. The pegboard is accessible from both sides. So far all seems to be working well, with full 100% access.
            Thanks for all the help. Regards, Steve
