With our remodel we had installed a lot of ceramic tile. Due to high spots in several places the molding will not go to the floor in some spots. Most are a matter of less than 1/8" and can be handled but have found a couple that are going to set the molding off by over 1/4" at each end if I split the difference. This just isn't exceptable. If it were a long run I could just bend it to fit but on the short runs bending doesn't seem possible. Tried sanding the bottom of the trim to fit the high spots and that did ok. Is that the way to handle the problem? How would you handle this situation?
Thanks
Steve
Thanks
Steve
