Been playinng around with sketchup and a workbench design. Being a garage shop with limited space I am trying to utilize the benchtop for maximum function and thought about building it to hold various benchtop tools where the work surfaces of the top of the bench and the tool would be level. This is what I have so far:
Middle panel is removable and benchtop tools rest on the adjustable shelf which raises and lowers using the through dado's in the side. Each tool will have a set of spacers that will register the top of the tool worksurface even with the benchtop.
One problem I see is that the stretcher supporting the top is not going to provide support like I have it now. I would like as much useable room on the bottom as possible for a large shelf to hold the tools. How should I support the top?
This will be my first bench so suggestions are appreciated.
Thanks
Steve
Thanks
Steve
