Source for veneer
  • Salty
    • 690
    • Akron, Ohio
    Source for veneer
    Has anyone here ever purchased from FormWood Industries, Jeffersonville IN ?
    They have a really wide selection and seems like decent pricing.
    Thanks.
  • Salty
    • 690
    • Akron, Ohio
    No one huh?
    Well, I'll let ya know how it goes.
    I ordered 2 pieces of 2'x8' Hickory NBL for $18.59 each today at noon. I got an order confirmation this evening, so far so good.
    • Salty
      • 690
      • Akron, Ohio
      Well, veneer was delivered today and seems to be in good condition.
      Both 2'x8' pieces were rolled together in a 1'x1'x2' box.
      Should I unroll this and store it flat since I will not be using it for a few weeks?
      • Lee4847
        • 200
        • Canton, Oh
        what does it look like? Is it figured and multi colored like the solid Hickory? I recently completed a project with hickory and realy like the way it looks. I did find out that it is much harder than Oak.
        Cut twice.... measure??
        • Salty
          • 690
          • Akron, Ohio
          I only pulled out the ends of the 2 pieces to see what it looked like. 1 piece is mixed with the light and dark and the other is more consistantly dark. However, that was just about 1 foot of the ends.
          Tough on tools too I'll bet! hehe
            The very few times that I have seen veneer in the raw, it is always stored flat. I would unroll it and make it flat as possible as soon as you can. If you have a flat piece of plywood under and over it to keep it flat, it would keep if from buckling in spots. Keep a weight on top too.
            That is the way I have seen it stored a couple of times.
            • Salty
              • 690
              • Akron, Ohio
              Thanks Hank. That was what I figure I should do. Good idea on the plywood. I do have some 4x8 sheets of CDX in the garage. I can rip one in half and use it top and bottom. Now all I have to do is figure out where to put up the 2'x8'.
              • Workman
                • 70
                Be careful about moisture in your plywood (stored in garage). If it is an unheated garage especially you may have too high moisture content which can affect your veneer if you sandwich it in between. Also can cause mold problems. With veneer you have little "clean-up" material left!
                  I thought about that also. The ones that I saw in the Memphis area were in unairconditioned warehouse and had a wide flat board on top.
                  The bunch I saw in Osaka was in a similar situation. In both cases, the veneer were very low moisture content to begin with. If the veneer were made from green wood, I would worry about that too. The Memphis bunch was several kinds and in racks with solid bottoms in the size that Salty mentioned; the stacks were not more than 3 to 4 inches think, if I remember correctly. The ones in Osaka were in stacks 8 to 10 inches thick and had heavy board stacked on top.
                  Evidently they were kiln dried. I didn't ask.
                  • Salty
                    • 690
                    • Akron, Ohio
                    Well, the plywood has been in the garage for nearly a year so it should be dry. But, I ripped a piece in half and brought it into the basement to warm up and dry out more. It will dry while I re-arrange some stuff to make room for the 2'x8'. I'll put down 4, 2x4x8 studs across some saw horses and sandwitch the veneer between the dried plywood. That way I will also have a large work area to redo the upper cabinets as I take them down.
                    I layed out the sheets on a table and some cardboard in the basement. It is pretty dry down here and it stays cool. It layed out flat right out of the box.
                    Here are some images of the grain. I think it looks good for $19 per sheet.
