Best veneering method
  • Salty
    • 690
    • Akron, Ohio
    I need to apply veneer to the ends of cabinets. I can sand down the old cabinet to prepare it but I am not sure what method to use. Contact adhesive? Get PSA backed? The largest areas are about 2' wide and 30" high.
    You are applying this veneer to cabinets in place? That is a tough one. I think I'd try a PSA backed. After that probably contact adhesive but for that you would have to cut the veneer oversize and trim it flush when dry.
    If I used contact adhesive, I'd apply the adhesive then tape several dowels spaced a few inches apart horizontally on the side of the cabinet. Then I'd start sticking the veneer at the top, tape the top edge in place and remove the dowels from the top down, sticking the veneer on as I go. Once all the dowels were out I'd roll the heck out of it with a j-roller or rolling pin.
    • Salty
      • 690
      • Akron, Ohio
      Thanks David.
      I was going to do the dowels but in a verticle fashion. I can hide a slite gap at the top since it is under the edge of the countertop but the edge against the wall will be the hard part. I can also trim it in the front since I an going to put 1/4" thick faceframe pieces over the old faceframe with a 1/8" return over the end. This will give the impression that the faceframe is a full 3/4" thick. The upper cabinets I plan to remove and rework but there are 2 end panels on the base cabinets to do.
      Should be an interesting job!
