I picked up a Freud Diablo at HD the other day for about $28. It is a D1024X and is supposed to be for ripping. Haven't opened it yet.
There are some differences between this one and their LU87R 10" blade. The plate is the same thickness at .071". The kerf on the Diablo is slightly thicker, .098 compared to .094", the hook angle is at 15 degrees where the LU is 20 degrees. Both also use ATB tooth patterns.
Supposedly the Diablo series is designed for the contractor and the LU series for the woodworker. Actually I know of contractors who are more of a 'woodworker' than I am.
I am thinking of trying this blade on some Hickory and cutting it like resawing. I'd be cutting some 4/4 stock 1/25 to 2.5" wide that needs to be a little over 1/4" thick and then it will be put through a planer to make faceframe covers.
Should I take it back and get a better blade?
