Hello,
Newbie here.
I'm starting my first "major" project -- a small bookcase for our office. I'm building it out of cherry plywood w/solid cherry trim, and would like to put a solid cherry top on it. The solid panel top is where I need some advice from those with more experience than I (should be most of you!).
I found some rough-cut cherry "shorts" (6' length) at our lumber yard, who planed them to S3S (6.5" x 13/16") for me. I plan to cut one into about 20" lengths, square the fourth edge of each with the table saw, and glue three pieces side-by-side to make the panel. Final dimension is ~17" x 16".
Here's the million-dollar question: since I don't have a joiner or a planer, is it possible to get these to match up reasonably well to look good? Can I successfully hand-plane the edges (and the face, once glued) with something like the GRÖZ Bench Plane, #3 Smooth, 9" #147636 available here:
http://www.woodcraft.com/family.aspx...lySpecial=True
Equipment cost, for the moment, is a concern... hence my desire to go with an inexpensive method such as a bench plane.
Also, can I route and cut across the grain after glue-up or will that affect the structural integrity of the panel?
Thanks for the advice,
kwc
Newbie here.
I'm starting my first "major" project -- a small bookcase for our office. I'm building it out of cherry plywood w/solid cherry trim, and would like to put a solid cherry top on it. The solid panel top is where I need some advice from those with more experience than I (should be most of you!).I found some rough-cut cherry "shorts" (6' length) at our lumber yard, who planed them to S3S (6.5" x 13/16") for me. I plan to cut one into about 20" lengths, square the fourth edge of each with the table saw, and glue three pieces side-by-side to make the panel. Final dimension is ~17" x 16".
kwc
