Outfeed table leg hinge?
  • scoly
    • Jun 2003
    • 395
    • Lubbock, Texas, USA.
    Have my outfeed table attached and am using a single leg for support. At present I am using this:
    http://www.rockler.com/product.cfm?p...er=leg%20hinge
    folding leg hinge. I have found that when I move the ts the hinge is not strong enough to keep the leg vertical. Although I rarely need to lower the outfeed table it is important to me that the option is there. Anyone have suggestions for a locking hinge that is strong enough for this application or an idea on using a regular hinge and locking it in position.
    Thanks
    Steve
    It\'s the combined experience of the members on this board that make it such a great place.
    If you're moving the TS around as I believe you indicated, this won't work as this extention is mounted too a shorter built on extension. But.. I'll throw it at you anyway as someone might catch and idea to ponder..
    Regards...
      Here is a locking leg bracket that might work:
      http://www.constantines.com/index.as...ROD&ProdID=737
      A THING OF BEAUTY IS A JOY FOREVER - John Keats
      • scoly
        • Jun 2003
        • 395
        Thanks for the replies. The saw does get moved around due to the confined work area and size of material. With the current hinge when I rotate the ts the leg does not stay vertical which puts a lot of pressure on the hinge and lowers the height of the outfeed table.
        Cabinetman, I do appreciate that you took the time to find these but they appear to be what I have.
        Looks like I may have to modify the current leg with a brace. Something that will support the side to side movement without letting the leg move.
        Thanks again.
        Steve
        • Steelnsilk
          • 6
          Table leg hinge
          Any single legged hinge will give if scraped against the floor. You might try a small caster on the bottom of the leg. Another sugggestion could be to cannabalize an 8' wooden table that it's legs fold up. Their legs fold flat when lowered. When raised a metal sleeve slides down and locks the table legs into place. I have seen these tables scooted all over at events and they seem to hold up pretty well. They always say two heads are better than one, perhaps this also applies to table legs/brackets?
          • dlminehart
            • 1829
            • San Jose, CA, USA.
            Steve, why not use two legs with a rail between them? And you might even put lightweight casters on the ends of the legs, so it would roll with the saw.
            - David
            • scoly
              • Jun 2003
              • 395
              Sorry! Should have mentioned that there is a caster on the leg.
              Two legs with a rail might do it but the idea for cannabalizing the folding table to get the sliding lock mechanism sounds like what I'm looking for.
              Funny how the simplest things can be so difficult to come up with. Had even thought about a folding card table leg but rather than the simple solution of taking one off to use was considering how to make my own.
              Thanks to all. Think this will solve my problem.
              Steve
