Here's an interesting question:
As I understand it, constructing simple speaker cabinets is most easily done using mdf and veneer due the tendancy of solid wood parts to expand or contract basically leading to failure (cracked wood or joints).
However, I know there are also strategies (joinery) for dealing with movement in service in solid wood furniture such as table tops.
What kind of joinery would allow for some movement in service in a speaker cabinet?
Could the joints still be sealed from the inside somehow (silicone or other flexible sealant) similar to what is done with the mdf speaker construction for improved response?
! Good Luck!
