That would be the wife requesting that. So, she has decided on a shoe rack as we enter the back door. I decided to make the ends like raised panel doors to match the cabinets. There's the problem. I don't have raised panel bits and buying a set right now is a point of contention. I read up on using the TS for cutting the relief around the panels and I can't imagine it coming out very smooth - lots of sanding imagine. OK, I'll live with that. Now, how can I match the recessed bead that goes around the inside of the door frame. I have a set of 35-bits-you'll-seldom-use and the bead bits are far larger than called for. So, what do you think? Cut a bead with what I have and cut it down on the TS? The little lady says, "Don't bother with it. Nobody but you will notice.
Thought?
Chiz
Thought?
Chiz
