I need to make a couple of doors to close off a storage closet in a bedroom, it's an odd shaped area because it's above the stairs. The doors need to be about 50"x18" each. I looked into some prebuilt shutter doors, but they were just too expensive ($200+).
I'd like to try my hand at making stile-and-rail doors. I have a very nice router table and a Makita plunge router (1/2" chuck), but I don't have a bit set. This will be a one-time project, so I'd rather not spend $120+ for a bit set. The interior panels will be plain 1/4" birch veneer plywood, so they will match the doors in the room. Stiles and rails will be made out of clear pine, and everything gets painted, so this is not fine cabinetry.
I found a ogee-pattern bit at Sears that is supposed to do stiles and rails, you swap the cutting parts around to make the pattern work. It's about $45. Anybody ever use this bit? I hate buying cheap tools and making compromises, but I just can't justify the expense for this one project.
). search by his user-id (holbren) for any of his posts, his sig-line has info.
