Good day
I know, there are many jigs to cut dadoes with router.
The problem is that part of them requires bearing guided bit that is more expensive and the commertial ones, yes, they cost and for amateure like me, that makes a few dadoes a year...
I would like to share with you my version.
First, the router is "locked" between two fences and cannot "jump" incidently.
Second, I know exactly where "the bit will hit" and
Third, I can use any straight bit.
I use it even to make loose tenon mortise.
The guide is made like the "T square - How to make" method so it's very accurate.
On the pictures, I made the marking example on MDF (for good contrast) but the actual routing, on chipboard
“See NOTE in text”
When you see on the picture “See NOTE in text”, I did not have space on the picture to type:
“You can make the same knife mark on the other side of the board and move the plate with the slot to the other side and check that the knife mark is at the same distance from the board edge. If it’s not, check the board for squareness or shim the T guide".
Regards
niki
“See NOTE in text”
Regards
niki
