I was working on the last stages of the cabinet doors for my bookshelf project. All I had left to do was drill the holes for the euro hinges and mount the doors. I did the first set (of 3) and everything was going fine. I grab the next door and started drilling. I was just finished when I realized to my horror that I had just drilled the holes in the FRONT of the door!
After cursing for five minutes and throwing a few things, I started thinking about how to fix the problem. The panels are cherry ply, with only one side having a decent grain pattern, so I can't just flip it. Apart from rebuilding the entire door, the only other option I see is to cut out the panel out, flip it over, and glue in some strips to hold the panel in. The question is: how to cut out the panel? I'm thinking I can use the router mounted in my BT3100 to route out most of it and the use a chisel on the rest.
Anyone have any other ideas or suggestions on cleaning up this mess? Right now, I just a bit disgusted with myself and could use a second opinion.
-- Ken
-- Ken
