Well, I usually don't have this much luck and get something to work out this well, but this one worked. Thought I'd share this with all and I can expand on it if needed. I'm about half way finished with an entertainment center and I needed to fit up the outside corners of the baseboard. My brother suggested putting a biscuit joint in there and I just groaned at the idea. I have a cheap Skil brand machine that is certainly not top of the line. After lots of thought I came up with a simple plywood fixture to hold the trim and the tool in the proper orientation. Here's the result.
(Next posts will show the finished corner)
