Can I rout an edge on baltic birch? I know I could try it, but no point in wasting wood if I don't have to. The finished project will be painted.
Baltic Birch Ply Question
\"Experience is the toughest teacher. You get the test first and the lesson later.\"Tags: None -
My experience has been that it turns out pretty nice.
You will rarely get a void like in regular PW.
May have to prime the edges as they might soak up paint pretty good.Brian
Welcome to the school of life
Where corporal punishment is alive and well. -
Thanks for the fast responses. It is time to fire up the router!!\"Experience is the toughest teacher. You get the test first and the lesson later.\"Comment
Just finishing a project that uses finger-jointed drawers, used 12mm Baltic for the sides. Worked great, very little tear out, make sure and use a backer board. The Baltic that I found has some great grain and figure, part of it looks like the Masur Birch that I've seen with the dark lines and wavy figure. Drawers turned out pretty nice.
KimMeasure it with a micrometer...
Mark it with a crayon...
Cut it with a chain saw!
Wood ButcherComment
Use a sharp bit and don't try to profile in one pass. Do a few, having the last just a skim run.
"I'M NEVER WRONG - BUT I'M NOT ALWAYS RIGHT"Comment
