Face Frame Alignment For Multiple Cabinets
    When installing multiple cabinets, there's the tedious task of getting the face frames to line up flush. This is a tip that may be of some help. For example if you have three upper cabinets each having their own face frame call the first "A", the second "B", and the third "C". If you've installed the face frame on the cabinets, lay them on their backs and line them up so the face frames are as close to flush as possible. Start with "A" and "B". Clamp the two FF's together. From whichever side you are comfortable drilling and screwing, drill pilot holes and countersink in at least three places (top, middle, bottom) from one FF into the other. Make sure the holes are not drilled where hinges will be installed. Insert screws that will be shorter by 1/4" to 1/2" than the ones you will use when installing. Bump screws in tight. Remove clamps. Do the final scraping or sanding on the two FF's at once so they are flat and even. Then go to the "B" and "C" cabinets and do the same thing, etc.
    When installing, after placing them where they are to go and leveling them, screw cabinets to the wall, but not up tight. Using the slightly longer screws, align the FF's, clamp, and insert screws into the same holes and bump tight. Then do the final tightening of the cabinets to the wall. If the wall is not flat,(how many are?) shimming the back of the cabinets may be necessary, so that there is no strain on the FF's. This method helps make final alignment easier.
  • drunkcat
    • 116
    • Elgin IL
    • BTK
    Thanks for the post. I am a little confused. I assume you are supposed to remove the smaller face frame screws prior to hanging? Where do the "slightly longer" screws go?
    Thanks!
    Scott
      Scott
      Just for an example, lets say your FF's are 2" each. When you clamp up two of them, you have to pilot a hole through one into the other. So, for this temporary assembly you might use 2 1/2" screws. After you have sanded the two faceframes so they arer flat to eachother, unscrew the 2 1/2" screws and take them out. When you are installing the cabinets you might use a 2 3/4" screw in the same holes. Or, if you havent stripped out the hole try the 2 1/2" screws, but seat them slightly deeper.
