I've used the Scotchbrite type pads for a long time. Just for the heck of it I took one and just placed it under the ROS (sandpaper still on the ROS) on a large panel, and it is easy to control and worked pretty good. I used the grey (0000 equiv), then white. Leaving the sandpaper on the ROS holds the pad like H&L, and you can flip it over. I haven't found 5" round H&L higher than 320, and this is an alternative. This might be old news.
