Removing bees wax?
  • jl
    • 91
    • Nova Scotia, Canada.
    Removing bees wax?
    Last week I turned a curly maple bowl for a friend. I finished it with a coat of paste wax (mix of beeswax and row linseed oil). My friend would like me to put a more durable finish on it, like danish oil. The piece is to be displayed at the hardwood mill, where he works.
    Do I have to remove the beeswax first? How would I do that?
    Thanks for your help.
    Jean-Luc
  • Tom Miller
    • 2507
    • Twin Cities, MN
    I guess I'd start with mineral spirits, and progress to lacquer thinner until you think you're getting it.
    Any chance you can re-chuck it and lightly sand?
    Regards,
    • jl
      • 91
      Thank you Tom. I'll try that.
      I thought about putting it back on the lathe, but I can not. There is nothing left to grab and I don't have a vacuum chuck.
      Jean-Luc
      • scmhogg
        • 1839
        • Simi Valley, CA, USA.
        Jean-Luc,
        Mineral spirits will dissolve wax. But, it will also allow the wax to penetrate more deeply.
        I would use the MS to get the majority of wax off the surface and let it dry thoroughly. I would then finish with several coats of shellac. Most shellac already has some wax in it and should not have any adhesion problems on your bowl.
        Zinssers has a pre-mixed shellac and a French polish, if you don't want to go through the hassle with flakes and alcohol.
        Steve
